JECaine
May 31, 2021Tutor
Google Home app cannot connect to devices from Home app since upgrading to MR60
Hey all. I've been having difficulty with my Google Home Devices ever since i got the MR60 Nighthawk Mesh devices. When I first connected the mesh network I was unable to cast to my Nest Display fro...
- Jun 17, 2021
I wanted to say thank you to anyone who responded and tried to help with this issue. No one here nor at Netgear knew how to fix it so I assume it was unique to me. I decided to buy 2 MoCA adapters which uses your existing coax in your home to broadcast a signal to other routers/wireless APs in your home. I was able to wire my Xbox and Tivo and get much better stability and
streaming quality. Plus that router is providing a wireless signal to the lower floors of my home and my google issue seems to be fixed! If anyone is curious about the MoCA technology, this is what I bought:
Thanks again
JC
Jeremywp123
Oct 13, 2025Aspirant
The solution seems to be to enable IGMP (Internet Group Management). Then restart your nest device. This is the protocol google uses to stream content and it seems to be disabled by default.
