JohnnyG3
Feb 03, 2024Aspirant
Had to hard reset MR60 twice in two weeks
I have an MR60 mesh system with two satellites. Twice within the last two weeks we have woke up in the morning to find we have no internet service. Both times it was some issue with the MR60 that r...
Feb 03, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Does the front LED on the MR and MS appear AMBER when this happens?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR📡 and MS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-WiFi-6-and-Tri-band-Mesh-WiFi-6-products 📡 ‌‌🛰
Are the MS wireless or ethernet connected to the MR?
️Does this happen with the MS turned OFF?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many
Armor, Smart Parental Controls or Circle, Traffic Meter.
JohnnyG3 wrote:
I have an MR60 mesh system with two satellites. Twice within the last two weeks we have woke up in the morning to find we have no internet service. Both times it was some issue with the MR60 that required a factory reset. Once the reset has completed, everything seems to work properly. I'm just curious if anyone else is having similar issues. Is it possible that it could be an issue with the firmware? Can these be rolled back?
Thanks
JG
