italianbeef
Aug 26, 2020Star
Help disabling Armor
Can someone help me figure out how to disable Armor? It's been causing me numerous issues, especially with video conferencing software. I go into the Nighhawk app -> Settings -> Security -> slide...
italianbeef
Aug 27, 2020Star
Yes - I've tried installing the app on another device, same problem. Rebooted router, restarted app.
Aug 27, 2020Guru - Experienced User
If you really want it disabled, factory reset the router and reinstall it.
- italianbeefAug 27, 2020Star
Thanks, but I've seen in other threads that doesn't work. The device is registered with the Armor service and it's immediately activated again after the factory reset?
plemans wrote:If you really want it disabled, factory reset the router and reinstall it.
