johnc847
Jan 27, 2021Tutor
Help with best mesh system and still have features of advanced router
Can someone help guide me to which solution would be better? Using a Nighthawk X6 Router with a X4S Tri-Band Wifi Mesh Extender, or would I be better off using an Orbi. My issue is getting faster inte...
johnc847
Jan 27, 2021Tutor
Performance goals I'm wanting are a solid non interrupted connection and about 500 down speed wise which I'm getting just haven't had long enough to see how stable the connection is going to be.
Jan 27, 2021Guru - Experienced User
The triband extenders are pretty stable and fast. Much better than dual/single band extenders or the dual band mesh systems.
As a single unit, I'd put them on par with the triband orbis. When you're needing more than 1 extender though, its better to go with something like orbi.
- johnc847Jan 28, 2021TutorThank you!
