BeefCowMoo
Sep 25, 2020Initiate
Hidden Network Problem with Nighthawk Mesh Wifi 6 System (AX1800)
I recently set up my Nighthawk Mesh Wifi 6 System and it works perfectly fine with almost all of my devices. However, my laptop is the only thing that can't connect to the network because the network...
- Sep 29, 2020
Here once more, the notebook vendors and Windows Update are very poor in providing current Wi-Fi adapter drivers. Well known issues are with Intel WI-Fi adapters which require current drivers - read updates - to recognize Wi-Fi 6 (802.11ax) wireless networks. The easiest way to deal with the Intel drivers does start here -> Intel Driver & Support Assistant
Not a Netgear issue - much more poor service by your notebook supplier.
schumaku
Sep 29, 2020Guru - Experienced User
- BeefCowMooSep 29, 2020Initiate
Thank you so much! After following the link you sent, I was able to update my drivers and connect to the network.
