ethernetping
Jun 03, 2022Aspirant
High Variable Ping when using Ethernet ( MK83 / AX3600 )
Model: MK83 / AX3600 Firmware: V1.1.6.14_3.1.101 (I've tried rolling back firmware) OS: Windows 10 and Windows 11, all computers really. Environment where Relevant: Most noticeable when playing g...
Jun 03, 2022Guru - Experienced User
what modem/gateway are you connected to?
Does it happen if you hardwire the gaming console into the modem?
- ethernetpingJun 03, 2022Aspirant
If I plug my laptop directly into the modem, it does not happen. I am using a CM1200 Nighthawk Modem, using the first ethernet port. My router is the only thing plugged in. I am not using a console, just play on my laptop.
One of the worst tests I've run. I've never seen an average of above <1ms on this test.
I don't understand how my ping could be 155 when I am plugged in.
- ethernetpingJun 21, 2022Aspirant
Bump. Still need help. When my friend runs the same test on his setup, its his average ms is 0. I still can't believe a router this expensive could be this bad
