ethernetping
Jun 03, 2022Aspirant
High Variable Ping when using Ethernet ( MK83 / AX3600 )
Model: MK83 / AX3600 Firmware: V1.1.6.14_3.1.101 (I've tried rolling back firmware) OS: Windows 10 and Windows 11, all computers really. Environment where Relevant: Most noticeable when playing g...
Jun 03, 2022Guru - Experienced User
what modem/gateway are you connected to?
Does it happen if you hardwire the gaming console into the modem?
ethernetping
If I plug my laptop directly into the modem, it does not happen. I am using a CM1200 Nighthawk Modem, using the first ethernet port. My router is the only thing plugged in. I am not using a console, just play on my laptop.
- ethernetpingJun 03, 2022Aspirant
One of the worst tests I've run. I've never seen an average of above <1ms on this test.
I don't understand how my ping could be 155 when I am plugged in.
- ethernetpingJun 21, 2022Aspirant
Bump. Still need help. When my friend runs the same test on his setup, its his average ms is 0. I still can't believe a router this expensive could be this bad
- EternalStudentJun 24, 2022Apprentice
I assume "ethernet" means plugging in to a satellite. That means it's using wifi as the backhaul to the base router. Still probably better than wifi to the satellite, then wifi to the router... but it's not a true ethernet connection. I don't remember if these have a LAN port on the router, but you could try plugging in there to verify the router itself isn't causing the issue.
My guess is interference from other stuff. Either bad channel selection (someone else is using the same or an overlapping channel), and picking a clearer channel will help.
Or interference from other devices like microwaves. They blast out noise when they run that can mess with a lot of networking devices. I think bluetooth can overlap with some wifi signals too.
Don't know if you have Quality of Service on for the router. I have it off so I can use my full bandwidth when I want, but that leaves some unused so devices can have time to get info through quickly. Large bandwidth users like streaming video or bittorrent can impact pings for others.
And sadly cost isn't always equivalent to quality. I'd thought my mk63 had a dedicated backhaul channel, but didn't spend the time to verify. If I had it to do all over again I'd probably buy an Asus router for their "AI" feature that can make a mesh out of many of their line. You can get 3rd party firmware too, so if they stop updating stuff you might still get bug fixes (though you run the risk of new security holes). I don't see the benefit to Netgear over TP-link for instance. I can't trust Netgear to create quality products based on their name alone. I have to nitpick their stats just like everyone else.
