jaymz69
Mar 20, 2021Apprentice
HomePod Mini Not working on MR60 Mesh WHEN Satellites are NOT Plugged in
After working with Apple support on this we came to the conclusion that the homepod mini can airplay fine (my Apple TV too) ONLY when none of the satilites are powered on. Works for all the AirPlay f...
- Nov 10, 2021When you upgrade/downgrade, always do it satellite first, router after:
103 beta for MR60 https://ntgr.my.salesforce.com/sfc/p/300000000xsV/a/0y00000056JP/J38PBLjMmRLFiBA.rZ3qMk516lZy0vHSpvBSeMBA_do
103 beta for MS60:
https://ntgr.my.salesforce.com/sfc/p/300000000xsV/a/0y00000056JQ/68c76CRT0ugwEUuOpPyVBJVosFw8z36VQqT3wzdV6RI
According to their support the fix should come in next firmware, in between you can try this.
jaymz69
Apr 30, 2021Apprentice
I have a ticket open with Apple now on this and that’s the same situation when we try to troubleshoot it once the satellites are off HomePod Apple TV iPod basically the airplay works perfect but once you get a satellite plugged in at airplay craps out they told me that’s on the Netgear but I can’t get a hold of anybody and Netgear says I have no warrantee I just bought it six months ago and I can’t even get the support or the help so it’s very frustrating can’t even return it the router that is.
jaymz69
Anybody from Netgear monitoring this really need to resolve this and need some help and support just can’t get a hold of anybody at Netgear to the resources that are available online Apple need to talk figure this out with you guys and it keeps pointing to next year’s satellite.
