jaymz69
Mar 20, 2021Apprentice
HomePod Mini Not working on MR60 Mesh WHEN Satellites are NOT Plugged in
After working with Apple support on this we came to the conclusion that the homepod mini can airplay fine (my Apple TV too) ONLY when none of the satilites are powered on. Works for all the AirPlay f...
- Nov 10, 2021When you upgrade/downgrade, always do it satellite first, router after:
103 beta for MR60 https://ntgr.my.salesforce.com/sfc/p/300000000xsV/a/0y00000056JP/J38PBLjMmRLFiBA.rZ3qMk516lZy0vHSpvBSeMBA_do
103 beta for MS60:
https://ntgr.my.salesforce.com/sfc/p/300000000xsV/a/0y00000056JQ/68c76CRT0ugwEUuOpPyVBJVosFw8z36VQqT3wzdV6RI
According to their support the fix should come in next firmware, in between you can try this.
GregCro
Jun 01, 2021Guide
Thanks. I tried turning off the private IP, but it didn't seem to fix the issues all the time. According to Netgear (social media team) a firmware update is in testing which would resolve the issue.
Ntlope
Jun 02, 2021Tutor
I'm having a similar issue where the Apple remote app on my iphone never finds the Apple TV. Also, I can't make phone calls from my Mac Mini because it says my iphone needs to be on the same wifi network (it is). Hopefully this gets fixed on a firmware update soon!
- NtlopeJun 02, 2021Tutor
All apple switching works if I switch off the MS60 satellites. So frustrating. I almost bought a service contract with Netgear to try and fix it and it turns out it's just a bug.
