jaymz69
Mar 20, 2021Apprentice
HomePod Mini Not working on MR60 Mesh WHEN Satellites are NOT Plugged in
After working with Apple support on this we came to the conclusion that the homepod mini can airplay fine (my Apple TV too) ONLY when none of the satilites are powered on. Works for all the AirPlay f...
MELso76
Jun 24, 2021Aspirant
I figured I may as well tack on my issue to this thread as I too am having problems with my new Netgear MK62 mesh kit when using my Homepods.
I recently purchased a MK62 Netgear mesh router (MR60) and satellite setup (MS60). Both devices have been updated to 1.0.6.110 (from https://kb.netgear.com/000063755/MR60-MS60-Firmware-Version-1-0-6-110).
I am having immense problems getting stereo playback on my two Homepods when the satellite is plugged in. Instead, only one Homepod plays music, while the other Homepod remains switched off. Both Homepods are located closer to the satellite than the router.
When I unplug the satellite, the Homepods play in stereo correctly (but then I have unreliable wifi at the back of my house).
I did not have issues using my previous Amplifi HD setup, suggesting it's a problem with how the Netgear is handling the mesh setup.
- MELso76Jun 24, 2021Aspirant
Further to my previous post, I have assigned static IPs to the two HomePods and this seems to have sorted the stereo playback issue (for now), suggesting there's an issue with DHCP or similar. (As an aside, I should not have to be assigning static IPs to devices to have them work properly.)
As for AirPlay, I too am finding that the Apple Private Address feature is conflicting with the ability to AirPlay through the mesh network. Once I turned the setting off, AirPlay worked properly. Netgear needs to review how its devices operate with this feature of iOS and update their firmware...
- jaymz69Jun 25, 2021Apprentice
I did the satlite and router manual formware install from the files thy sent in the link above and after that my AirPlay so far for the last couple days workd for once!!!!! Christian_R MELso76
I did what they wanted for the firmware patch and it works now for me - though I only have 1 HomePod Mini.
Hello jamz69,
We recently re-published firmware v1.0.6.110. May you reinstall the firmware version linked below.
Christian
- bollee23Jun 25, 2021Tutor
This firmware is just the one I already have (MR60 and MS60). How is it supposed to fix the issue ?
The link they gave is the same FM name but it is updated code (not sure why they did not increment it) and after I followed the instructions for each satalite & router (Netgear Interface Update even said the same name and I said "Yes" install anyways) and once it was all updated, I tested out the AirPlay issues (even AirPlay to AppletTV or from the Mac it would have the same issue) and they worked perfect! Before it would not work at all, it would hang up and then not find it.
