jaymz69
Mar 20, 2021Apprentice
HomePod Mini Not working on MR60 Mesh WHEN Satellites are NOT Plugged in
After working with Apple support on this we came to the conclusion that the homepod mini can airplay fine (my Apple TV too) ONLY when none of the satilites are powered on. Works for all the AirPlay f...
MELso76
Jun 24, 2021Aspirant
Further to my previous post, I have assigned static IPs to the two HomePods and this seems to have sorted the stereo playback issue (for now), suggesting there's an issue with DHCP or similar. (As an aside, I should not have to be assigning static IPs to devices to have them work properly.)
As for AirPlay, I too am finding that the Apple Private Address feature is conflicting with the ability to AirPlay through the mesh network. Once I turned the setting off, AirPlay worked properly. Netgear needs to review how its devices operate with this feature of iOS and update their firmware...
jaymz69
Jun 25, 2021Apprentice
I did the satlite and router manual formware install from the files thy sent in the link above and after that my AirPlay so far for the last couple days workd for once!!!!! Christian_R MELso76
