jaymz69
Mar 20, 2021Apprentice
HomePod Mini Not working on MR60 Mesh WHEN Satellites are NOT Plugged in
After working with Apple support on this we came to the conclusion that the homepod mini can airplay fine (my Apple TV too) ONLY when none of the satilites are powered on. Works for all the AirPlay f...
- Nov 10, 2021When you upgrade/downgrade, always do it satellite first, router after:
103 beta for MR60 https://ntgr.my.salesforce.com/sfc/p/300000000xsV/a/0y00000056JP/J38PBLjMmRLFiBA.rZ3qMk516lZy0vHSpvBSeMBA_do
103 beta for MS60:
https://ntgr.my.salesforce.com/sfc/p/300000000xsV/a/0y00000056JQ/68c76CRT0ugwEUuOpPyVBJVosFw8z36VQqT3wzdV6RI
According to their support the fix should come in next firmware, in between you can try this.
GregCro
Jun 25, 2021Guide
I have manually updated the firmware for both the main router and the satellite, and this has not fixed my Airplay issues. One Homepod mini seemed to be connected to the satellite and the other to the main router (they are both in my main bedroom where the satellite is located). Airplay to the Homepod mini connected to the router worked, but the other Homepod connected to the satellite did nothing. Once I unplugged the satellite Airplay and Handoff worked just fine, so in summary this update did not seem to fix the issue for me.
brendanc
Jul 01, 2021Tutor
I also attempted the manual upgrade of firmware for both the router and the satellite. This resulted in Airplay working for about 10 mins or so until my Homepod connected to the Satellite. Once connected to the Satellite, it is visible from my phone but attempting to connect always fails. Unfortunately, it makes the MK62 system not fit for purpose.
GregCro wrote:I have manually updated the firmware for both the main router and the satellite, and this has not fixed my Airplay issues. One Homepod mini seemed to be connected to the satellite and the other to the main router (they are both in my main bedroom where the satellite is located). Airplay to the Homepod mini connected to the router worked, but the other Homepod connected to the satellite did nothing. Once I unplugged the satellite Airplay and Handoff worked just fine, so in summary this update did not seem to fix the issue for me.
- fredb777Jul 05, 2021Aspirant
I also tried a manual update with the new firmware hotfix: https://kb.netgear.com/000063806/MR60-MS60-Firmware-Version-V1-0-6-112-Hot-Fix
No change...
- NtlopeJul 06, 2021Tutor
No change for me either. homePod still not working
- Christian_RJul 07, 2021NETGEAR Employee Retired
Hello,
For those still experiencing issues with your HomePod and MR60, please send me a private message with the following info. I'd like for our support team to reach out for further assistance.
Email:
Phone:
Preferred Contact Time: (including time zone)
Router Serial Number:
Current Firmware Version Installed:
Thanks,
Christian
- NtlopeJul 30, 2021TutorDo we have a fix for this yet? Still not working
