jaymz69
Mar 20, 2021Apprentice
HomePod Mini Not working on MR60 Mesh WHEN Satellites are NOT Plugged in
After working with Apple support on this we came to the conclusion that the homepod mini can airplay fine (my Apple TV too) ONLY when none of the satilites are powered on. Works for all the AirPlay f...
Choppers
Sep 10, 2021Tutor
Add me to the list of people still looking for a solution. I may need to return this to Amazon before I’m outside the return window. I wish there was some concrete information about the progress with addressing this issue.
- jaymz69Sep 11, 2021Apprentice
At elast you can return it still, I did not get a HomePod and find out it did not work with my currrent hardware/AirPlay2 until after my return peroid expired and the support for Netgear also expired; they want me to pay money to fix their issue - which is clearly not ONLY my issue.
Netgear really, really, needs to put this up as a priority 1!
I just pulled out a smart plug that I need to use outside and it will not work either on the netgear mesh system. It keeps wanting me to be on the same network, so it cannot distinguish between the two satilites on the mesh system either.
HELLO, Netgear, can you hear us now?
- jaymz69Oct 08, 2021Apprentice
Anyone having luck with this working on iOS 15????? I cannot still cannot use my Apple devices with AitPLay on a Mesh system with Netgear!!!! EVen other smart devices from other vendors (non Apple) ALSO FAIL!!!! nothing seems to like he Netgear Mesh system!!! NEATGEAR PLEASE HELP BEEN OVER A YEAR!!!!
- FURRYe38Oct 08, 2021Guru - Experienced User
Have you asked Apple for help and support information regarding there features? Maybe an Apple issue and Apple could lend a hand in seeing where the issue is.
