jaymz69
Mar 20, 2021Apprentice
HomePod Mini Not working on MR60 Mesh WHEN Satellites are NOT Plugged in
After working with Apple support on this we came to the conclusion that the homepod mini can airplay fine (my Apple TV too) ONLY when none of the satilites are powered on. Works for all the AirPlay f...
- Nov 10, 2021When you upgrade/downgrade, always do it satellite first, router after:
103 beta for MR60 https://ntgr.my.salesforce.com/sfc/p/300000000xsV/a/0y00000056JP/J38PBLjMmRLFiBA.rZ3qMk516lZy0vHSpvBSeMBA_do
103 beta for MS60:
https://ntgr.my.salesforce.com/sfc/p/300000000xsV/a/0y00000056JQ/68c76CRT0ugwEUuOpPyVBJVosFw8z36VQqT3wzdV6RI
According to their support the fix should come in next firmware, in between you can try this.
Oct 08, 2021Guru - Experienced User
Have you asked Apple for help and support information regarding there features? Maybe an Apple issue and Apple could lend a hand in seeing where the issue is.
jaymz69
Oct 08, 2021Apprentice
They did months ago and the higher tier engineers took logs and combed through them for 2 weeks and came back wi th netgear not passing through correctlly when it should be "like" the same network though on a satilite. They even had me unlpug the satilites and everything worked once onlt the main router on and all the devices where in range on it. Sent back to Netgear and never head back...
