jaymz69
Mar 20, 2021Apprentice
HomePod Mini Not working on MR60 Mesh WHEN Satellites are NOT Plugged in
After working with Apple support on this we came to the conclusion that the homepod mini can airplay fine (my Apple TV too) ONLY when none of the satilites are powered on. Works for all the AirPlay f...
- Nov 10, 2021When you upgrade/downgrade, always do it satellite first, router after:
103 beta for MR60 https://ntgr.my.salesforce.com/sfc/p/300000000xsV/a/0y00000056JP/J38PBLjMmRLFiBA.rZ3qMk516lZy0vHSpvBSeMBA_do
103 beta for MS60:
https://ntgr.my.salesforce.com/sfc/p/300000000xsV/a/0y00000056JQ/68c76CRT0ugwEUuOpPyVBJVosFw8z36VQqT3wzdV6RI
According to their support the fix should come in next firmware, in between you can try this.
DariosaurusRex
Oct 26, 2021Guide
I was told today to go get another one from Costco and “try” to see if it works out… seriously
jaymz69
Oct 26, 2021Apprentice
Really? Wow, at least you were told something, and what about ALL the others customers with the same issue Netgear???? I just posted this thread on Twitter on Netgear... see if we can get some traction on this.,..
- DariosaurusRexOct 26, 2021GuideI had a couple of tweet going out as well.
- GregCroOct 27, 2021Guide
I was contacted via Twitter DM (after posting on their Twitter). A support person is supposed to be contacting me, so we'll see if that helps. 🤷♂️
- DariosaurusRexOct 27, 2021Guide
i guess two tweet in one day about it, just did it... let me know if they come up with the "oh, you'll have to return it" solution
