jaymz69
Mar 20, 2021Apprentice
HomePod Mini Not working on MR60 Mesh WHEN Satellites are NOT Plugged in
After working with Apple support on this we came to the conclusion that the homepod mini can airplay fine (my Apple TV too) ONLY when none of the satilites are powered on. Works for all the AirPlay f...
Arkhyle
Oct 28, 2021Tutor
Hi,
A correction has been developped the 3rd of March 2021 and it works:
MR60-V1.0.6.103_21.03.03_homepod.chk
MS60-V1.0.6.103_21.03.03_homepod.chk
but it is still not impemented in the current release MR60-V1.0.6.116_2.0.54.chk.
One workaround is to wire (when possible) the satellite MS60 with the MR60.
DariosaurusRex
Nov 04, 2021Guide
So the software is not released yet? Also I thought the Ethernet port was to connect a peripheral device. Didn’t think I could connect the satellite with the router. Wouldn’t defeat the purpose of being wireless
- FURRYe38Nov 04, 2021Guru - Experienced User
Though ethernet connected MS offer ethernet connected support in cases where wireless may not be good. Wire has better operation and performances over wireless.
Possible not having MS not connected via ethernet is revealing a problem with HomePod devices.
- ChoppersNov 04, 2021Tutor
As stated, wiring the satellite defeats the purpose of a mesh system. The benefit of having a mesh system is that it is a simple plug and play solution to extend the range of a wifi network. If I wanted to wire, I could have gotten a router and switch.
- DariosaurusRexNov 04, 2021GuideI agree. I have my house wired in, so I could do that, but why should I do that because NetGear won’t fix the issue.
