jaymz69
Mar 20, 2021Apprentice
HomePod Mini Not working on MR60 Mesh WHEN Satellites are NOT Plugged in
After working with Apple support on this we came to the conclusion that the homepod mini can airplay fine (my Apple TV too) ONLY when none of the satilites are powered on. Works for all the AirPlay f...
- Nov 10, 2021When you upgrade/downgrade, always do it satellite first, router after:
103 beta for MR60 https://ntgr.my.salesforce.com/sfc/p/300000000xsV/a/0y00000056JP/J38PBLjMmRLFiBA.rZ3qMk516lZy0vHSpvBSeMBA_do
103 beta for MS60:
https://ntgr.my.salesforce.com/sfc/p/300000000xsV/a/0y00000056JQ/68c76CRT0ugwEUuOpPyVBJVosFw8z36VQqT3wzdV6RI
According to their support the fix should come in next firmware, in between you can try this.
Arkhyle
Nov 10, 2021Tutor
Yes you can roll back
Arkhyle
Nov 10, 2021Tutor
103 beta for MS60:
103 beta for MS60:
- jaymz69Nov 10, 2021Apprentice
It is a few updates back from the curret one, so it used to work before? I never had it work fo me for the last year... See what happens...
Current Firmware Version:
V1.0.6.116_2.0.54Uploaded Version:
V1.0.6.103_21.3.3 - jaymz69Nov 10, 2021Apprentice
The instructions say do ROUTER first the SATILITE on the ADMIN update page - why ackwards?
WOW! Everytime I update them (AND I have disabled auto firmaware update and Applied) somehow they ALL keep updateing back to v.116 , I cannot keep the router or the satilites (2 each) on the v.103 for the FW, they keep updateing back to v.116 eventhough I have auto disabled.
It just keeps getting better, I really need to just throw these away and invest in the Eero ones, I see they work with Apple Homekit too. Better App from what my friend shows me too. Cut my loss and lesson learnend with Netgear.
- FURRYe38Nov 11, 2021Guru - Experienced User
Do you happen to have a upstream router by chance in front of the MR?
- jimjohn101Nov 11, 2021Aspirant
I downgraded to this yesterday and my homepods have worked perfectly since, thanks for sharing!
