jaymz69
Mar 20, 2021Apprentice
HomePod Mini Not working on MR60 Mesh WHEN Satellites are NOT Plugged in
After working with Apple support on this we came to the conclusion that the homepod mini can airplay fine (my Apple TV too) ONLY when none of the satilites are powered on. Works for all the AirPlay f...
- Nov 10, 2021When you upgrade/downgrade, always do it satellite first, router after:
103 beta for MR60 https://ntgr.my.salesforce.com/sfc/p/300000000xsV/a/0y00000056JP/J38PBLjMmRLFiBA.rZ3qMk516lZy0vHSpvBSeMBA_do
103 beta for MS60:
https://ntgr.my.salesforce.com/sfc/p/300000000xsV/a/0y00000056JQ/68c76CRT0ugwEUuOpPyVBJVosFw8z36VQqT3wzdV6RI
According to their support the fix should come in next firmware, in between you can try this.
Nov 23, 2021Guru - Experienced User
đ
GregCro
Nov 25, 2021Guide
I have just updated my satellite and router to Version 1.1.6.122. Haven't been on here in a few weeks, but I spent over an hour on the phone with netgear stupport essentially helping them collect logs and bug fix. They then sounded pissed off when I wasn't able to answer the phone during the work day! To top it off they called multiple times on Thanksgiving day :-/
Going to see if Version 1.1.6.122 fixes things. Does anyone know of a good way to check if the homepod minis are connected to the router or the satellite? For me that would be the critical test to show it's working, but as of now I don't know how to verify if they're connected to the router or satellite. Thanks!
Greg
- TroyCoDec 14, 2021Tutor
Ive tested V1.1.6.122 for a few days. It does make the Airplay system work with multiple homePods but it has introduced a new issue.
Normally when you say "Hey Siri" and you have two or more homepods within earshot, the one that picks up your voice the clearest takes the command.
THis update now causes all homepods (within earshot) to execute the command indepentantly - for example, if you said "Hey Siri play some music", both homepods would each start playing random music.
- FURRYe38Dec 14, 2021Guru - Experienced User
Maybe space the homepods farther appart?
