jaymz69
Mar 20, 2021Apprentice
HomePod Mini Not working on MR60 Mesh WHEN Satellites are NOT Plugged in
After working with Apple support on this we came to the conclusion that the homepod mini can airplay fine (my Apple TV too) ONLY when none of the satilites are powered on. Works for all the AirPlay from any device - once I have the satilite(s) powered on the AirPlay will not work. Apple said that is on the Netgear's seetings somewhere and contact them So any one ese have this issue?
Thank you,
James
- When you upgrade/downgrade, always do it satellite first, router after:
103 beta for MR60 https://ntgr.my.salesforce.com/sfc/p/300000000xsV/a/0y00000056JP/J38PBLjMmRLFiBA.rZ3qMk516lZy0vHSpvBSeMBA_do
103 beta for MS60:
https://ntgr.my.salesforce.com/sfc/p/300000000xsV/a/0y00000056JQ/68c76CRT0ugwEUuOpPyVBJVosFw8z36VQqT3wzdV6RI
According to their support the fix should come in next firmware, in between you can try this.
- SuggymotoAspirantAdding my name to the list. When I try to search for a firmware update on the Nighthawk app for iOS it fails to search. Currently running v1.0.6.116_2.0.54 and unable to use any AirPods (of which I have 2 full size and 1 mini)
Always check here as well for FW updates:
https://www.netgear.com/support/
Suggymoto wrote:
Adding my name to the list. When I try to search for a firmware update on the Nighthawk app for iOS it fails to search. Currently running v1.0.6.116_2.0.54 and unable to use any AirPods (of which I have 2 full size and 1 mini)- SuggymotoAspirantThanks. Can firmware be rolled back to a previously known good version? I see they’re there to download.
- jeremeepInitiateAirplay was intermittently working on 1.1.16.122 but might have resolved it by turning on MU MIMO in advanced - wireless settings.
