tbyc808's avatar
tbyc808
Tutor
Feb 27, 2022
Homepod mini only works with my iPhone 11 Pro on MS60 satellite
My Hompod Mini is connecting with the MR60 mesh router (located at living room). When my iPhone 11 Pro connects to MR60 (located at bed room), the Homepod Mini can be found. However when I connect my ...
  • plemans's avatar
    Feb 27, 2022
    I know iphones are now using random mac addresses. If you disable that option, and connect/reconnect a few times or re-associate the homepod, does it work?
