Jmthorner
Jan 07, 2021Aspirant
How can I see what the data usage is for each device connected to MR60?
I have the nighthawk MR60 and our data has gone sky high all of a sudden. Is there a way to see how much data each connected devices are using? Nothing has changed in terms of our usage from what w...
Jan 07, 2021Guru - Experienced User
its literally the most requested feature.
Bandwidth monitoring by device - NETGEAR Communities
Sadly, its not available.
You'll kind of have to do it the hardway by not using a few devices each day and monitoring daily usage to see how its changed.
- pillaiveluFeb 02, 2021Aspirant
I seem to have a similar issue. Since past 2 months seeing a spike in usage, where it seems to be exceeding monthly limit of 1.2TB (did not realize Xfinity had this limit). Nothing specific changed in terms of usage. Have been using Netgear Nighthawk MR60 for past 6 months. Unfortunately, don't see an option to find bandwidth/data usage by device.
Any other options? Surprising that Netgear MR60 does not have this feature.
