dalemwebb
Jan 13, 2023Aspirant
How do I check my MODEM settings through my Nighthawk M60 MESH router?
I know how to log in and use the web-based Nighthawk configuration utility to see my ROUTER settings. How do I check my MODEM settings?
- Jan 13, 2023
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Kitsap
Jan 13, 2023Master
dalemwebb wrote:I know how to log in and use the web-based Nighthawk configuration utility to see my ROUTER settings. How do I check my MODEM settings?
What specific brand name and model number modem do you have? (Look on the label)
There is usually not a lot of user configurable settings on a modem only device.
- dalemwebbJan 13, 2023AspirantIt's a CenturyLink C3000Z (Zyxel modem/router combo), but I'm pretty sure I have the modem bridged so I can use the Nighthawk mesh router. Just wanted to confirm modem settings.
- KitsapJan 13, 2023Master
dalemwebb wrote:
It's a CenturyLink C3000Z (Zyxel modem/router combo), but I'm pretty sure I have the modem bridged so I can use the Nighthawk mesh router. Just wanted to confirm modem settings.A good place to start is with the OEM.
https://www.centurylink.com/home/help/internet/modems-and-routers/zyxel-c3000z.html
Unfortunately, when I:
Open a web browser and type http://192.168.0.1 into the web address fieldIt fails to load.When I type http:\\192.168.1.1 into my browser, I get the Nighthawk user interface.Is it not possible then to get to the MODEM interface since the modem is bridged?
