dalemwebb
Jan 13, 2023Aspirant
How do I check my MODEM settings through my Nighthawk M60 MESH router?
I know how to log in and use the web-based Nighthawk configuration utility to see my ROUTER settings. How do I check my MODEM settings?
- Jan 13, 2023
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
dalemwebb
It's a CenturyLink C3000Z (Zyxel modem/router combo), but I'm pretty sure I have the modem bridged so I can use the Nighthawk mesh router. Just wanted to confirm modem settings.
Kitsap
Jan 13, 2023Master
A good place to start is with the OEM.
https://www.centurylink.com/home/help/internet/modems-and-routers/zyxel-c3000z.html
- dalemwebbJan 13, 2023Aspirant
Unfortunately, when I:
Open a web browser and type http://192.168.0.1 into the web address fieldIt fails to load.When I type http:\\192.168.1.1 into my browser, I get the Nighthawk user interface.Is it not possible then to get to the MODEM interface since the modem is bridged?- FURRYe38Jan 13, 2023Guru - Experienced User
I'd ask the ISP if this is the case if there modem IS bridged, can it's web page be access. I remember some DSL gateways from years ago that when bridged were not accessible with the web page since it was in bridge mode. They had to be factory reset to get back to there web pages. Possible same with this modem you have.
If it's in bridge mode and you have the MR working as your router, then you should be ok and would not need to do anything to the modem while in bridge mode. Unless you need to troubleshoot something.- dalemwebbJan 13, 2023Aspirant
Now, when I try to log into http://192.168.1.1, I get an error:
Router Password Reset
We can help you reset your router's admin password. You need your router's serial number, which can be found on the router label. Enter your router's serial number in the field and click the Continue button.Your Device is disabled, Please try again in 5 minutes.
Enter the router's Serial Number
I have entered the router (Nighthawk) serial number and "successfully" reset the password 3 times. Still when I try to log in, I get the same error.
HELP!
