dalemwebb
Jan 13, 2023Aspirant
How do I check my MODEM settings through my Nighthawk M60 MESH router?
I know how to log in and use the web-based Nighthawk configuration utility to see my ROUTER settings. How do I check my MODEM settings?
- Jan 13, 2023
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
dalemwebb
Don't know what happened. Got through to 192.168.1.1 with my new password. Thanks everybody.
Jan 13, 2023Guru - Experienced User
Enjoy. 📡
