novermyhead
Feb 25, 2020Aspirant
How do i Create a Mesh system with a Nighthawk X 10?
I am currently using a Nighthawk X10 r9000 Router and while i am please with its performace,I am finding a few dead zones in my house. I have looked at the Orbi system but I dont really want to puirc...
Feb 25, 2020Guru - Experienced User
You can add a mesh extender to your network. They work amazing if you're only adding 1. When/if you start needing more than 1 extender, thats when you should be looking into the true mesh setup instead of just a mesh extender.
How big is your home?
What are the interior walls made of?
- novermyheadFeb 25, 2020Aspirant
My home is around 2500 Square feet. Most all place are covered exepct my bedroom. The wall are typical 2x4 with 3/4 in sheet rock. Would i need to purchase just one of the Orbi,or should i go with the Nigt Hawk Mesh system?
- plemansFeb 25, 2020Guru - Experienced User
Your home should probably be fine with single extender. But thats a "probably" because many things can influence wireless coverage.
Quite a few stores have generous return policies so if you bought a mesh extender and tried it and it didn't provide the coverage you desire, you could return and switch to mesh.
The x10 is quite capable as a router. I'd probably start with adding the tri-band mesh extender and seeing how it performs.
- novermyheadFeb 27, 2020AspirantThank you so much for the help. I’ll start looking at the tru and mesh extenders. Any suggestions on model
