novermyhead
Feb 25, 2020Aspirant
How do i Create a Mesh system with a Nighthawk X 10?
I am currently using a Nighthawk X10 r9000 Router and while i am please with its performace,I am finding a few dead zones in my house. I have looked at the Orbi system but I dont really want to puirc...
Feb 25, 2020Guru - Experienced User
You can add a mesh extender to your network. They work amazing if you're only adding 1. When/if you start needing more than 1 extender, thats when you should be looking into the true mesh setup instead of just a mesh extender.
How big is your home?
What are the interior walls made of?
novermyhead
My home is around 2500 Square feet. Most all place are covered exepct my bedroom. The wall are typical 2x4 with 3/4 in sheet rock. Would i need to purchase just one of the Orbi,or should i go with the Nigt Hawk Mesh system?
- plemansFeb 25, 2020Guru - Experienced User
Your home should probably be fine with single extender. But thats a "probably" because many things can influence wireless coverage.
Quite a few stores have generous return policies so if you bought a mesh extender and tried it and it didn't provide the coverage you desire, you could return and switch to mesh.
The x10 is quite capable as a router. I'd probably start with adding the tri-band mesh extender and seeing how it performs.
- novermyheadFeb 27, 2020AspirantThank you so much for the help. I’ll start looking at the tru and mesh extenders. Any suggestions on model
- plemansFeb 27, 2020Guru - Experienced User
Depends on what the area you're trying to cover.
I'd take a look at the renewed/refurbs on amazon for orbi. The wireless AC versions can be bought pretty reasonable now that the new AX routers are being released.
I've had 2 sets since the Orbi's first came out and they've been great. Everyone once in a while there is a bad firmware but the Orbi's have gotten more firmware updates than any other router product I've seen so it doesn't last long.
