novermyhead
Feb 25, 2020Aspirant
How do i Create a Mesh system with a Nighthawk X 10?
I am currently using a Nighthawk X10 r9000 Router and while i am please with its performace,I am finding a few dead zones in my house. I have looked at the Orbi system but I dont really want to puirc...
novermyhead
My home is around 2500 Square feet. Most all place are covered exepct my bedroom. The wall are typical 2x4 with 3/4 in sheet rock. Would i need to purchase just one of the Orbi,or should i go with the Nigt Hawk Mesh system?
Feb 25, 2020Guru - Experienced User
Your home should probably be fine with single extender. But thats a "probably" because many things can influence wireless coverage.
Quite a few stores have generous return policies so if you bought a mesh extender and tried it and it didn't provide the coverage you desire, you could return and switch to mesh.
The x10 is quite capable as a router. I'd probably start with adding the tri-band mesh extender and seeing how it performs.
- novermyheadFeb 27, 2020AspirantThank you so much for the help. I’ll start looking at the tru and mesh extenders. Any suggestions on model
- plemansFeb 27, 2020Guru - Experienced User
Depends on what the area you're trying to cover.
I'd take a look at the renewed/refurbs on amazon for orbi. The wireless AC versions can be bought pretty reasonable now that the new AX routers are being released.
I've had 2 sets since the Orbi's first came out and they've been great. Everyone once in a while there is a bad firmware but the Orbi's have gotten more firmware updates than any other router product I've seen so it doesn't last long.
