jphensleyjr
Jun 05, 2023Aspirant
How to configure EasyMesh devices to work with NightHawk mesh router
I see that the NightHawk Mesh routers support EasyMesh. How do you add an EasyMesh device to the mesh? I have tried putting the device in pairing mode using the add satellite as though it were a Ni...
- Jun 05, 2023
might be cheaper to just add another satellite. I think the MS60 and MS80 are both compatible with it.
Jun 05, 2023Guru - Experienced User
What router do you have?
the only one I know that potentially had it was the MK series but I'm not sure if it was fully part of the EasyMesh standard.
jphensleyjr
I have the MK83. MR80 router with 2 MS80 satellites.
