jphensleyjr
Jun 05, 2023Aspirant
How to configure EasyMesh devices to work with NightHawk mesh router
I see that the NightHawk Mesh routers support EasyMesh. How do you add an EasyMesh device to the mesh? I have tried putting the device in pairing mode using the add satellite as though it were a Ni...
- Jun 05, 2023
might be cheaper to just add another satellite. I think the MS60 and MS80 are both compatible with it.
jphensleyjr
I am trying to extend my mesh wirelessly. Wired is not an option. I am trying to reach a piece of equipment that is too far for my satellite. I can use the device in repeater mode, but I would prefer a seamless single network with the same SSID to support other devices. The non-Netgear device supports EasyMesh.
Jun 05, 2023Guru - Experienced User
What device is it?
Are the satellites sync'd fine?
What error does the other device give you?
did you contact them to see about different methods of setting up? Sometimes wps doesn't work the best.
