jphensleyjr
Jun 05, 2023Aspirant
How to configure EasyMesh devices to work with NightHawk mesh router
I see that the NightHawk Mesh routers support EasyMesh. How do you add an EasyMesh device to the mesh? I have tried putting the device in pairing mode using the add satellite as though it were a Ni...
- Jun 05, 2023
might be cheaper to just add another satellite. I think the MS60 and MS80 are both compatible with it.
jphensleyjr
I have it working this way. I thought I could avoid the extra SSIDs. I may have to switch router brands to get what I'm looking for. Thanks.
Jun 05, 2023Guru - Experienced User
- jphensleyjrJun 05, 2023AspirantI need outdoor capability. I've broke an Orbi by putting it outside. Netgear recommended and outdoor Orbi, but that was a bit pricey. I'm satisfied with extender mode for now. May check on TP-Link the next time I upgrade my router. They appear to fully support EasyMesh.
