italianbeef
Aug 01, 2020Star
How to conifgure smart light bulbs with Nighthawk MR60
I'm afraid of the answer I'm going to get...but can you configure smart light bulbs with the Nighthawk MR60? They almost all require 2.4ghz (at least to initially connect). This also requires the mob...
schumaku
Nov 26, 2020Guru - Experienced User
paulz Yes and no.
The problem does go ways beyond of the initial IoJ discovery. In a Mesh environment, additional APs can become available at any time adding coverage to the SSID Mesh, offering much better signal level for the wireless clients. Because these IoJ device WiFi clients are much to cheap, they won't take care about the neighbourhood information distributed offering alternate APs on air, they won't automatically re-iterate the situation, they won't re-associate to better AP.
With a mobile device like an old tablet or notebook which does come and go to the network this isn't a big issue - it will most likely re-associate to the temporarily best radio on every reconnection. More static infrastructure devices like smart lights (switches, bulbs, ...) or e.g. wireless printers/scanners it's becoming much more critical. These devices will remain up 24*7, except of a power failure virtually never - so these IoJ will never re-associate and take any advantage of the Mesh system.
paulz
Nov 27, 2020Aspirant
Great comments. Learning from you. But man. No way manufacturers will do it. I think I just got disappointed by some cheap ass plugs tonight. How ironic. Lol.
- striker69Mar 03, 2021Star
I Found That You Need To Use 2.4 mhz, I Have An Older Tablet That Connect's With 2.4. Once You Connect The Smart Bulb You Can Use Other Devices Even If They Are On 5 mhz.
