italianbeef
Aug 01, 2020Star
How to conifgure smart light bulbs with Nighthawk MR60
I'm afraid of the answer I'm going to get...but can you configure smart light bulbs with the Nighthawk MR60? They almost all require 2.4ghz (at least to initially connect). This also requires the mob...
Gillian37
Mar 03, 2021Initiate
I ended up buying Phillips Hue as it had a hub, it would not work with LIFX, but the hub connected no problems, the light bulbs talk to the hub, everything worked. I have no patience for workarounds, it should just work
