Biggsamus's avatar
Jan 19, 2023
How to dismantle MS60?
One of my silly family members placed silly putty on top of our MS60, and by the time I noticed, some had entered through the top ventilation holes.
Anyone have instructions for how to dismantle the device safely so I can remove the silly putty?
Thankyou
  • Oh oh.
    I haven't taken one apart however there maybe a screw under each rubber foot that could be removed and unscrewed.
  • FURRYe38's avatar
    Oh oh.
    • Biggsamus's avatar
      Biggsamus
      Tutor
      Awesome thankyou Furry, took the screws out and was super easy to get into the case, a fair bit of putty had made it through, so I'm glad I've got it out!
      • FURRYe38's avatar
        Glad you got it open and cleaned out. đŸ˜‰
        Enjoy.
