EternalStudent
May 08, 2023Apprentice
How to enable DFS channel use? MK63 (aka MR60 + 2 x MS60)
One area listing all devices that support DFS channels (any at all) lists my product. But another page that lists WHICH of the possible DFS channels each product will support lists nothing. https:/...
May 08, 2023Guru - Experienced User
What Region are you located?
EternalStudent
May 09, 2023Apprentice
I'm in the US. That's the region it lists on the advanced page. I don't think I can change it (grayed out). I don't remember if I ever manually set it or if it just figured out where I am on it's own.
I'll admit to considering changing the region to try out the channel 13 option, away from most people in 2.4GHz. But as I said...isn't possible that I know of.
(Update) I just expanded all 4 regions on the DFS channels supported page, just in case they don't exist until I expanded them. No model listed included "mr", "ms", or "mk" using find in the browser.
- FURRYe38May 09, 2023Guru - Experienced User
Probably not supported on the MK series MESH system then.
