WaiMan
May 16, 2020Tutor
How to hidden SSID on Nighthawk MK62
I bought Nighthawk MK62 but I'm not found where to hidden my SSID.... Please teach me. Thanks and Best regards.
- Aug 05, 2020Hi waihongso and WaiMan,
The problem deemed to be solved after I upgrade the firmware to the latest one (released on 3 Aug 2020). You can download them (for both router and satellite) through the link below:
https://kb.netgear.com/000062170/MR60-MS60-Firmware-Version-1-0-5-102
Anthony
Christian_R
May 20, 2020NETGEAR Employee Retired
Hi WaiMan,
Please log into the router by visiting the admin page. Then click on ADVANCED>Advanced Setup>Wireless Settings and uncheck the "Enable SSID Broadcast" box.
Christian
WaiMan
May 20, 2020Tutor
Dear Christian
Thank you for your advice.
I had try this method but I can't find out "Enable SSID Broadcast" box on admin page.....
Thanks and best regards
WaiMan
- Christian_RMay 22, 2020NETGEAR Employee Retired
Hi WaiMan,
May you provide me with a screenshot for us to check along with the firmware version your router is currently on.
Thanks,Christian
- WaiManMay 22, 2020Tutor
Dear Christian
Thank you for your reply.
The firmware version is V1.0.492_2.0.38 I'm using now.
Please confrim my attached.
Thank you and best regards
WaiMan
- WaiManJun 14, 2020Tutor
Dear Christian
I had send you my screenshot but haven't recivied any reply.
Please kindly to confirm it again I attached.
I still can't find out any check box on Advanced>Advanced setup> wireless setup
Tam WaiMan
- Christian_RJun 18, 2020NETGEAR Employee Retired
Hello WaiMan & nmcant,
Please update to the latest firmware version and let me know how it turns out.
https://kb.netgear.com/000061928/MR60-MS60-Firmware-Version-1-0-4-96
Christian
