WaiMan
May 16, 2020Tutor
How to hidden SSID on Nighthawk MK62
I bought Nighthawk MK62 but I'm not found where to hidden my SSID.... Please teach me. Thanks and Best regards.
- Aug 05, 2020Hi waihongso and WaiMan,
The problem deemed to be solved after I upgrade the firmware to the latest one (released on 3 Aug 2020). You can download them (for both router and satellite) through the link below:
https://kb.netgear.com/000062170/MR60-MS60-Firmware-Version-1-0-5-102
Anthony
waihongso
Jun 28, 2020Aspirant
Hi Christian,
I've just bought this model of router and got the exactly same problem, would you be able to give me the solution as well once your team have a solved this issue?
Thanks
Thanks
nmcant
Aug 05, 2020Guide
Anthony
Anthony
