J-Pluto
Nov 12, 2024Follower
How to reset router after power outage
My power went out today and when it turned back on the router has been stuck on amber. Tried power cycling, tried factory resetting and it’s not budging. I tried going through gateway and it allows me...
michaelkenward
Nov 13, 2024Guru - Experienced User
What router do you own? Which LED is amber? What does the power LED look like?
Power cuts usually take out both the modem and the router on a network. When the power comes back on, they may start up in the wrong order, with the router starting before the modem is ready. That means that they get confused about which is in charge.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
Just another user with time on their hands.
