legendgao
Apr 01, 2020Aspirant
how to set Mesh EAX80 to 160MHZ and 4.2Gbps?
now i use EAX80 mesh with my old route R6250 with 5G channel 44 and 2.4G channel auto(11), then i find EAX80 show, the max traffic is 2.4gbps for 5G with channel 36,40,44,48 and 600mbps for 2.4G. ...
- Apr 02, 2020the R6250 isn't an AX device and doesn't support 160hz channel width. The EAX80 is running off it if you're running in extender mode.
If you want to test the eax80 fully functional, hardwire it into the R6250 and then set it in AP mode. This lets it use the ethernet connection as the backhaul and you can change the wireless to whatever you want in the EAX80
Apr 02, 2020Guru - Experienced User
- legendgaoApr 02, 2020Aspirant
thanks for your explain,answered my questions
But do you think, Isn't the design reasonable? now i use Wifi5 for backfual, why it will impact the WIFI6 full speed access for extend?
it's should be independent.
- plemansApr 03, 2020Guru - Experienced User
legendgao wrote:thanks for your explain,answered my questions
The router is the backbone of the system. It all runs off it.
compare it to a hose.
If at the start of a hose, you've got a garden hose. On the other end, you connect a monster fire hose. Just because you attached a fire hose to the end that can put out thousands of gallons of water, doesn't mean the garden hose is going to allow it because its limiting the flow.
Or compare it to cars if you go that route. You could have a 1000 horsepower motor but if you're feeding it with a small 4 cyclinder stock gas pump, it can't supply the fuel to run that much horsepower.
that's what you've got. You've got an extender thats capable of much faster speeds but you limited it with running off a R6250. you have to look at where the bottleneck is in any system and fix that.
- legendgaoApr 04, 2020Aspiranti know u mean.
may be i need show the picture for this problem. i will add picture later.
now only say 5Ghz example, the eax80 connect to 6250 5Ghz speed is about 1gbps, and eax80 5Ghz wifi speed show 2400mbps. so i am confuse why it's not show 4800mbps?
