mdfsandman
Jun 29, 2024Aspirant
How to setup an MR60 mesh system as a bridge
I got a MR60 mesh system to extend my range of the wifi. I have a Calex Exos router that was supplied by my internet provider. The range does not extend far enough. I bought a MR60 mesh system but ...
mdfsandman
Jun 30, 2024Aspirant
I tried to put my modem straight to the MR60 router but it says that it is not connected to the internet. I have to plug it into a TP Link switch and then to the Calix router to get an internet connection. That is what is throwing me for a loop. I am usually pretty good and connecting computers and setting up routers and such but this has me stumped. I have put the MR60 in AP mode but it now shows 2 connections with the same name and I am still not able to get my cameras to cross over them. I connected the MR60 straight to the calix router but the light stays red and there is no internet on the MR60 and I can't connect to it. I am lost on this one!
michaelkenward
Jun 30, 2024Guru - Experienced User
What is that modem?
What says "it is not connected to the internet"?
When you are playing around with devices, remember to reset the devices and restart the network in the right order:
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
- mdfsandmanJun 30, 2024Aspirant
The light on the MR60 staying red is what is telling me it is not connected to the internet and also my phone will connect to the wifi but it says no internet. Thanks for the information.
- FURRYe38Jul 11, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
