iamck
Dec 11, 2020Guide
How to use MR60 Router as a Satellite
Hi All I have 2 kits and want to make them into one giant mesh if possible. I understand that you can make the MR60 router into a Satelitte but I cant find the settings? My initial kit of on...
Christian_R
Dec 16, 2020NETGEAR Employee Retired
Hello iamck,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
