burrata42
Nov 30, 2021Follower
HP Deskjet 3510 connect to NETGEAR Nighthawk MK63 AX1800 WiFi 6 Mesh System
I recently got the NETGEAR Nighthawk MK63 AX1800 WiFi 6 Mesh System. I'm trying to connect a HP Deskjet 3510printer to the new WiFi system. How can you connect the HP Deskjet 3510 to the MK63 AX1800 ...
Nov 30, 2021Guru - Experienced User
where is it failing in the setup process?
Are you using wps or following the HP's install guide?
Did you check on their forum since its the printer that connects to the router and not the other way around?
