JimShane
Feb 11, 2022Guide
I added 3 new satellites two days ago, all was working today - All satellites went to red lights
I have the AX1800 Nighthakw Mesh system wit h MR60 Router and now 9 MS60 satellites. On Tuesday, I added 3 new satellites to the system - everythign worked fine. The firmware on the router was...
- Feb 12, 2022
You're using 9 satellites?
are they hardwired in?
running over wireless?
You can use more than the recommended amount of satellites but if you're using wireless, I'm surprised its working at all as you're way over the recommended amount.
https://kb.netgear.com/000064360/How-many-satellites-can-I-add-to-a-Nighthawk-Mesh-WiFi-system
michaelkenward
Feb 12, 2022Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Mesh System - NETGEAR Communities
Those things are different from the standard Netgear routers covered in this section.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
