ngear_user_us
Oct 17, 2022Follower
I can sometimes gain access via direct connection to wired ethernet port
I am having the same problem and have had to reset three times now.
It started a couple of months ago. I can sometimes gain access via direct connection to wired ethernet port, but the conne...
Oct 17, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Does the front LED change from BLUE to Amber when this happens?
Can you access the MRs web page at all?
