JoeyAnthony
May 18, 2022Aspirant
I can't set my DNS servers
Did you ever find out a solution to this problem? I just picked up an MR80 and updated the firmware and now I can't set my DNS servers either. I usually have them set to Google, but now I seem to be stuck using the ISP. I've tried rebooting, connecting from multiple different browsers, but nothing works.
JoeyAnthony did you try starting your own thread?
- JoeyAnthonyAspirant
Sorry, plemans there was a thread here with the exact same problem so I figured I'd add to it instead of creating another thread with no solutions. I guess I can go go create my own thread.
- OM-M80Aspirant
Never found a solution. I even tried it on a different OS and got the same result. It really is the router and Netgear isn't acknowledging this issue. Not cool.
