Krixtian
Feb 08, 2024Initiate
I have a MR80 with 2 MS80s and I think I finally got to the bottom of this issue
I have a MR80 with 2 MS80s and I think I finally got to the bottom of this issue. This has happened to me multiple times before and I’d just fix it by changing the SSID and connect everything one by ...
Feb 09, 2024Guru - Experienced User
Or once you have everything setup, you go into the router and setup reserved IP addresses for those specific devices causing the issues. that should prevent that issue
- KrixtianFeb 10, 2024InitiateOMG, that’s a great idea, I never thought of that, thank you!! It took me 2 days to get all my devices connected again. With reserving IPs, I should be safe after a power outage.
I’m suspecting the issue are my Google Nest Cameras because those were the only ones that wouldn’t connect to the new SSID through the app until I hold down their reset button and start fresh.
