Freak2277
Jul 30, 2024Aspirant
I have a nighthawk mesh wifi 6 router MR80, it stopped working
My router stopped working and my internet provider says it might have reset itself. How done set it back up.
- Jul 30, 2024
Ok.
Just FYI, you don't have to use the NH app to install the router. There is a link at the bottom of the 1st setup page that you can use a PC and web browser to set it up, next time.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Jul 30, 2024Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Freak2277
Thank you. I ended up resetting and reinstalling the router. I stopped for no reason. But seems like it is fine now. I had to download an app.
- FURRYe38Jul 30, 2024Guru - Experienced User
Ok.
Enjoy. 📡
