phi303's avatar
phi303
I have both R8500 and Nighthawk Mesh - How do I get to the UI of the Mesh router via browser???
So I've moved into a house much larger than my old apartment and started adding a bunch of ip cams, smart switches, and smart plugs and my Nighthawk R8500 just wasn't cutting it anymore, dropping con...
  • plemans's avatar
    Nov 06, 2020
    Page 67 of the router goes through setting the mk63 in access point mode
    https://www.netgear.com/support/product/mk63.aspx
    I'd also make sure that if you leave the wireless enabled on the R8500 to have them on different channels from the mk63 to prevent interference
