kylo40
Feb 10, 2023Follower
I replaced the Nighthawk Mesh better known as Netgear Nightmare Mesh w/ an old TP-Link Archer 1200!
I replaced the Nighthawk Mesh better known as Netgear Nightmare Mesh w/ an old TP-Link Archer 1200! Didn’t have to rest a single thing after using same SSID & password on it! Unlike Nightmare Mesh wh...
Feb 10, 2023Guru - Experienced User
Are you wanting help getting your system going better? Or just venting frustration?
just checking what you'd prefer.
If you're wanting help, more details are needed.
1. what model mesh do you have (look at the label)
2. what firmware is on the router and on the satellites?
3. what backhaul are you using? (wired/wireless)
4. what modem/gateway is the mesh connected to?
5. What actual issue are you having in detail. Just saying it drops isn't enough. What actually happens? It says connected, no internet. IT doesn't broadcast at all? Etc. Details are key.
