Brendajackson12
Apr 09, 2023Tutor
I switched to Starlink for my internet. It works fine in my house but signal can’t get to garage.
Switched to Starlink as I live in remote are of Oregon. Works fine in my house but my garage can’t get signal. It is about 15 feet away. What can I do to boost signal so I can use it in my studio ...
- Apr 10, 2023
Brendajackson12 wrote:
I have. Nighthawk mesh system that I used with last IP but can’t figure out how to attach to Starlink modem.What's the Starlink modem.
Some satellite thing out of Star Wars?
As plemans says, no reason why the Nighthawk mesh system – which one? – shouldn't work with it.
That sounds easier if the two 70 yo womanYouth! Streets ahead of you.
Apr 09, 2023Guru - Experienced User
You have a couple options that I'd recommend trying.
1. (what I'd consider the best) is to run an ethernet wire between the 2 and use a mesh system so the satellite is in the garage and hardwired in.
2. If you get full service in the window, you could use a mesh system and put a satellite in that window to use.
3. you could try putting a wireless extender in the window of the garage. I'm partial to the triband extenders as they have a dedicated backhaul between router----extender.
- michaelkenwardApr 10, 2023Guru - Experienced User
Brendajackson12 might like to consider option 4, if the mains circuit accepts it, is Powerline Ethernet.
If the garage is on the same mains circuit as the house, and doesn't have a separate electrical circuit with lots of fuse boxes and isolators, you can turn the main into a fake LAN connection.
But option 1 beats everything else.
- Brendajackson12Apr 10, 2023TutorThat sounds easier if the two 70 yo woman without a lit if tech expertise. Is there a link you could share as to how to accomplish this.
I have. Nighthawk mesh system that I used with last IP but can’t figure out how to attach to Starlink modem. I just need simple if that is possible. Thank you- plemansApr 10, 2023Guru - Experienced User
You can attach it to the starlink and setup the Mesh setup in access point mode.
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
