Brendajackson12's avatar
Apr 09, 2023
I switched to Starlink for my internet. It works fine in my house but signal can’t get to garage.
Switched to Starlink as I live in remote are of Oregon.  Works fine in my house but my garage can’t get signal.  It is about 15 feet away.  What can I do to boost signal so I can use it in my studio ...
  • michaelkenward's avatar
    michaelkenward
    Apr 10, 2023
    Brendajackson12 wrote:
    I have. Nighthawk mesh system that I used with last IP but can’t figure out how to attach to Starlink modem.
    What's the Starlink modem.
    Some satellite thing out of Star Wars?
    As plemans says, no reason why the Nighthawk mesh system – which one? – shouldn't work with it.
    That sounds easier if the two 70 yo woman
    Youth! Streets ahead of you.
